tcf-agent kills bare metal app
Petalinux/Vivado 2017.4
Configuration AMP - Linux on ARM0 and Baremetal app running on ARM1 (not using open amp)
When I start my Linux application(elf) using the system debugger/tcf-agent, my bare metal application running on ARM1 dies.
Thanks in advance for any suggestions.
Re: tcf-agent kills bare metal app
How is your R5 application being loaded (is it by FSBL?) Are any of the peripherals in your baremetal application are also used by the Linux application?
figured out the "Real" problem.
I used the 2017 Petalinux configuration page to set the memory size for the Linux to be 0x20000000 but I noticed that the boot messages showed it using 0x40000000.  (double checked everything)
I then set the memory size using the Linux boot command mem=512M and everything works.
Just for your records this memory bug cost me 2 weeks.
