what's the differences between openamp and amp?
Hi, all
    I am so confused about the openamp and amp? what's the differences between openamp and amp?
    in the forum, I found some guys use openamp, and other guys use amp?
    someone give me some hints? thanks a lot!!!
   Tom
check these links
http://www.wiki.xilinx.com/OpenAMP
http://www.wiki.xilinx.com/Multi-OS+Support+(AMP+%26+Hypervisor)
Thanks and Regards
Balkrishan
Hi, Balkrishan
       Thank you for your reply, I have read the link of your offered, but I still don't understand the difference, in my opinion, the difference is that amp is older framework and open amp is latest framework, is that correct?
      Tom
