where can I download libmetal?
Hi, all
I download open-amp source code, the readme.md say that we should download libmetal and compile it? the original words below:
OpenAMP uses CMake for library and demonstration application compilation. OpenAMP requires libmetal library. For now, you will need to download and compile libmetal library separately before you compiling OpenAMP library. In future, we will try to make libmetal as a submodule to OpenAMP to make this flow easier.
But I can't find any information about libmetal source code? someone can give me some hints? Thanks!!!
Tom
Re: where can I download libmetal?
I run instruction: yum install libsysfs_devel*, so it can make successful
check this link
https://github.com/OpenAMP/open-amp
Thanks and Regards
Balkrishan
Hi, Balkrishan
    Thank you for your reply,  through the link https://github.com/OpenAMP/libmetal, I can download the libmeal source code, and I follow the steps which describle in the https://github.com/OpenAMP/open-amp, it say below:
  • Install libsysfs devel and libhugetlbfs devel packages on your Linux host.
  • build libmetal library on your host as follows:
        $ mkdir -p build-libmetal
        $ cd build-libmetal
        $ cmake <libmetal_source>
        $ make VERBOSE=1 DESTDIR=<libmetal_install> install
when I run cmake <libmetal_source>, it prompt error: could NOT find LIBSYSFS(missing: LIBSYSFS_LIBRARY LIBSYSFS_INCLUDE_DIR)
what can I do for this error? can you give some suggestions? Thant you very much!!!
Tom
I have run the instruction: yum install libsysfs , yum install libhugetlbfs and installed the two libs successful
