where to get the demo that the libmetal work with select() function based on linux user space application
Hi everyone,
when read the README.md of libmetal library, I found the following information,
### Interrupt
libmetal provides APIs to register an interrupt, disable interrupts and restore
interrupts.
The Linux userspace implementation will use a thread to call select() function
to listen to the file descriptors of the devices to see if there is an interrupt
triggered. If there is an interrupt triggered, it will call the interrupt
handler registered by the user application.
but I can not get any demo application source code includes the select() funtion released in the following site address, can you tell me where can I found this demo that libmetal work with select() function ?
https://github.com/OpenAMP/libmetal
Re: where to get the demo that the libmetal work with select() function based on linux user space application
https://github.com/Xilinx/meta-openamp/tree/rel-v2018.2/recipes-openamp
I believe this is the repo you a re looking for.  I agree that these example programs are hard to find.
Hmmm, can't find an edit button for my reply.
I forgot to say, change the "branch" to whichever release of Vivado/Petalinux you're working with.  The link I gave is on the 2018.2 branch.
I have got those source code I am interested, as the attached files.
The poll function call is linuxcall to wait on a fd
http://man7.org/linux/man-pages/man2/poll.2.html
