基于xc7k325t 用selectio ip核 生成iserdes实现7:1的LVDS视频接口接收
按图一所示ip核设置  clk输出时钟为什么是clk_div(7分频后的时钟)?
不应该是输出7倍频后的时钟么????
Re: 基于xc7k325t 用selectio ip核 生成iserdes实现7:1的LVDS视频接口接收
Since you have a serialization factor of 7, the clk_div is 1/7 of your data clock.  The clk_div will be the same rate as your received clock.  The PLL/MMCM will be used to generate a bit clock (Rx_clk * 7) and a pixel clock (Rx_clk).  This is explained in XAPP585.
Thank you
