Observer aniket
1 GHz or 800MHz with help PLL or CLK free counter work possible?
hello everyone,
I am working with the Spartan-6 sp605 board and there I have created a counter with 1Ghz or 800MHz clock or PLL  with working or not? please, specific answer replies me.
thanks
Observer avt_agui
Re: 1 GHz or 800MHz with help PLL or CLK free counter work possible?
Datasheet P56 I think that it is impossible to see the specifications of FMAX in Table 48.
https://japan.xilinx.com/support/documentation/data_sheets/ds162.pdf
Mentor jmcclusk
Mentor
If you are trying to measure an external clock of 800 or 1 GHz,  you might be able to do that by bringing it directly into a flip-flop clock input, and dividing it by 2.   But it's certainly true that you can't run a global clock tree at 800 Mhz..   400 MHz is the limit for Spartan6.
@aniket as @avt_agui has explained the Fmax for the BUFG in Spartan-6 is 400Mhz - Table 48 page 56 of the DS above. you cannot hit that 1 Ghz speed. The ISERDES can sample @ 800Mbps using the BIFG or @ 1080Mbps using the BUFPLL and doing a Double Data rate. But that is just sampling and not a counter.
If you want a counter and so the FPGA fabric running at these speeds then the limitation is the Fmax of the BUFG.
