100Mhz Clock Pinout (Nexys4)
Hi all,
I do generate 100Mhz and 10Mhz clock signal using Clocking Wizard IP
and I try to signal out through MRCC GPIO Pin.
I measured two clock signal by oscilloscope,
10Mhz clock signal is ok but 100Mhz clock signal is not measured(zero Signal).
Is there hardware out frequency limit??
Thanks for reading my message^^
This is very simple VHDL Code.^^
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
library UNISIM;
use UNISIM.VComponents.all;
entity main is
Port ( clock_in : in STD_LOGIC;
reset_in : in STD_LOGIC;
clock_10M : out STD_LOGIC;
clock_100M : out STD_LOGIC);
end main;
architecture Behavioral of main is
signal clock_locked : std_logic := '0';
component clk_gen
port
(-- Clock in ports
clk_in : in std_logic;
-- Clock out ports
clk_100M : out std_logic;
clk_10M : out std_logic;
-- Status and control signals
reset : in std_logic;
locked : out std_logic
end component;
begin
amd_clk : clk_gen
port map (
-- Clock in ports
clk_in => clock_in,
-- Clock out ports
clk_100M => clock_100M,
clk_10M => clock_10M,
reset => reset_in,
locked => clock_locked
end Behavioral;
check the following link for the datasheet of artix-7 fpga which provides you the mmcm specs
http://www.xilinx.com/support/documentation/data_sheets/ds181_Artix_7_Data_Sheet.pdf
I believe you are referring to this board
https://www.digilentinc.com/Data/Products/NEXYS4/Nexys4_RM_VB2_Final_5.pdf
could you share your xci file of the clocking wizard to check the settings
Thanks for reply. :)
It was All My mistake.
I'm a beginner of FPGA.
I really appreciate your reply.
@nickby Is the issue solved?
-Pratham
