3 to 1 MUX Clock with BUFGMUX
I am using Artix7 board
I have 3 clocks, say CKL1, CLK2 and CLK3, each one gtwizard_0_GT_USRCLK_SOURCE of the transceiver and input is given to the gtwizard_0_CLOCK_MODULE and the output from this is 3 different clocks . And I want to choose one of these three clocks at a time .
I firstly use one BUFGMUX to select CLK1/CLK2, then use another BUFGMUX_1 to select the first BUFGMUX output(CLK_OUT1) and CLK3.  Then get the final selected CLK_OUT.
(CLK1,CLK2) --> BUFGMUX --> (CLK_OUT1, CLK3)-->BUFGMUX_1 -->CLK_OUT.
But this will introduce this error.
 ERROR: [Place 30-120] Sub-optimal placement for a BUFG-BUFG cascade pair.
Could anyone provide suggestions?
Akshay
Scholar drjohnsmith
Re: 3 to 1 MUX Clock with BUFGMUX
I would suggest your imediate problem, the bufg , is that the gtx wizard has instantiated bufg's.
Scholar drjohnsmith
Hi @drjohnsmith ,
The problem is not that the xcvr has instantiated bufg, think like I have 3 clock input but at a time I want to use one clock so how can we over come the error
Hi @drjohnsmith ,
The problem is not that the xcvr has instantiated bufg, think like I have 3 clock input but at a time I want to use one clock, so how can I over come the above posted error  when I make use of bufgmux
Akshay
Scholar drjohnsmith
Your the expert then,
