7-series GTX TXUSRCLK2 issue
Hello
I want to used 7-series transceivers IP.
Why does the parameter is the same, but the TXUSRCLK2 frequency is different
Re: 7-series GTX TXUSRCLK2 issue
Hello @quincyq2003,
In case of blue frame pointed in your post, you are actually sending 4-byte data on 2-byte internal datapath. So to accomplish this, TXUSRCLK2 frequency is half of TXUSRCLK frequency.
Ashish
Hi @quincyq2003
It is dependent on the TX_INT_DATAWIDTH (0 or 1).
Thanks,Vijay
Hello @vijayak
If interface width is 2-byte, then TX_INT_DATA_WIDTH=0.
In table 3-3, What can i implement blue frame?
Hello @quincyq2003,
Ashish
Thanks for your help!!
