7-series transceiver 8b/10b comma alignment issue
Hello
I want to used 7-series transceiver IP, and used 8b/10b option.
In my test design, GTX can't alignment data.
The comma alignment will used K28.5 standard.
How to resolve this issue?
Simulation: Behavior
FPGA device: XC7V2000T
Vivado version: 2016.4
sysclk: 60MHz
Reference Clock: 156.25MHz
RX/TX Line Rate: 3.125Gbps
Re: 7-series transceiver 8b/10b comma alignment issue
hi,
On the Comma alignment page, did you deselect RXSLIDE and check ENPCOMMANALIGN and ENMCOMMAALIGN ports in the Optional Ports window?
If not, please do that and regenerate the IP.
Boris
Hello @borisq
In 7-series transceiver wizard, RXSLIDE and check ENPCOMMANALIGN and ENMCOMMAALIGN ports not enable, than comma alignment is also not success.
as said, you have to enable ENPCOMMAALIGN and ENMCOMMAALIGN.
Hello @borisq
The ENPCOMMAALIGN and ENMCOMMAALIGN is enables, but GTX is also not alignment.
please show me the waveform with the following signals:
ENPCOMMAALIGN
ENMCOMMAALIGN
RXDATA
RXCHARISK
RXCOMMADET
RXBYTEREALIGN
RXBYTEISALIGNED
RXCHARISCOMMA
Hello @borisq
In the below, there signals will dump to waveform.
rxcommadet doesn't go high. this indicates the comma is not detected.
when you send TXDATA=01bc, did you set TXCHARISK to 2'b01 in the same TXUSRCLK2 cycle?
Hello @borisq
I will follow your recommand.
When TXDATA=01bc, than TXCHARISK is setting 2'b01.
In this waveform, the rxcommadet to high, it mean comma detect, but not success to alignment.
I see comma alignment is successful because rxbyteisaligned goes high and keeps high. rxcommadet and rxbyterealign pulses also indicate a detection and alignment is done.
something strange is rxdisperr. what about rxbufstatus?
something wrong in your design.
please run the simulation with example design generated automatically.
what about rxresetdone?
Hello @borisq
The rxresetdone is High.
i see the problem.
you set TXCHARISK to 2'b01 permanently. this is incorrect.
you should set TXCHARISK to 2'b01 in the TXUSRCLK2 cycle when you sent xxBC.
when you send regular data, it should be 00.
TXCHARISK[0]=1 indicates TXDATA[7:0] is K char.
TXCHARISK[1]=1 indicates TXDATA[15:8] is K char.
Hello @borisq
In this waveform, when TXDATA sent xxbc, than TXCHARISK will sent 2'b01.
In this condition, GTX also not alignment.
txcharisk belongs to TXUSRCLK2 clock domain.
why is it longer than one period?
txcharisk and txdata is sampled by the same rising of TXUSRCLK2.
Hello @borisq
The txcharisk and txdata are relatation TXUSRCLK2 clock domain, but not alignment.
Anything setting not check?
txcharisk still wrong.
for example, when you send TXDATA=01bd, then txcharisk should be 00, but in the simulation it is 10.
when you send 01bf, txcharisk should be00 but you set it to 01
Hello @borisq
The GTX still not alignment
this time the waveform looks good.
you should look at the data several cycles after rxbyteisaligned goes high.
before it goes high, the comma is not detected so the data is not aligned.
the data is aligned after several cycles after rxbyteisaligned being high.
Hello  @borisq
Thanks for your help!!!
In my design, GTX can be successed to alognment, but must in post-implementation timing simulation.
In behavior simulation can not alignment.
This issue is correct?
