7VX690T-RF1761 Virtex7 Lid Material/Composition
Hi -
We’re in the process of purchasing dummy die from Topline to use in our test vehicle. We also know we can get Topline’s dummy die with lid material/composition in either stamped 98Cu/2Ni or Al-SiC. I’m having some issues browsing through Xilinx UG’s to figure out what the lid material and composition is for 7VX690T-RF1761 Virtex7?
I came across a product change notice from Xilinx, see attached “XCN16004 - Forged to Stamped XCN16004 - Lid Conversion for Monolithic FPGA Flip Chip Packages.pdf” that refers to selected 31mm and 35mm FC packages will remain be Stamped Lid Ni Plated (Cu 98Cu/2Ni) but it does not list the 690T on the change notice.
My question is, can someone help verify the lid material/composition for the 7VX690T-RF1761 Virtex7 as this will help generate an accurate CTEs, thermal and reliability projection and most importantly, help us order the right dummy die from Topline?
Thank
Ade Sanusi
Re: 7VX690T-RF1761 Virtex7 Lid Material/Composition
Hello @sanusi21
You can package specifications for your device at : https://www.xilinx.com/products/silicon-devices/fpga/virtex-7.html?resultsTablePreSelect=xlnxdocumenttypes:Package%20Specifications#documentation
You need check material declaration datasheet for package of your device.
For example XC7VX690T with package FFG1761 check for https://www.xilinx.com/support/documentation/package_specs/pk554_ffg1761.pdf and pk555_ffg1761_ipc.pdf
Bhushan
