janaka
AMS targeted reference design on VC 707 - How can I download the design and which version of Vivado to be used?
Hello:
I am trying to use AMS targeted reference design using VC 707 evaluation board. I have Vivado 2016.4, Vivado 2017.3 and Vivado 2018.1. I tried to use Vivado 2016.4 as the user guide (UG960(v5.0)) dated November 22, 2013.
* Can I use this example with this Vivado version?
I downloaded the xadc_eval_design_vc707_v1_4 and trying to follow UG 960. The steps are not clear with Vivado 2016.
* How can I rebuild this design using Vivado 2016 (or later)? It asks to browse hardware/vivado/scripts and run xadc_eval_design_gui
Should this open Vivado ?
I am getting following error:
Vivado% source xadc_eval_design_gui.tcl
# source xadc_eval_design.tcl
## set design_top xadc_eval_design
## set device xc7vx485tffg1761-2
## set proj_dir runs
## set impl_const ../../sources/constraints/system.xdc
## create_project -name ${design_top} -force -dir "../${proj_dir}" -part ${dev
e}
ERROR: [Coretcl 2-99] Project xadc_eval_design is currently open. Please close
he project before executing this command
while executing
"source xadc_eval_design.tcl"
(file "xadc_eval_design_gui.tcl" line 3)
* I am also getting some warnings about missing parts when I open the AMS101_Evaluator GUI as shown in the attached file.
Has it been installed properly? I didnt have any errors during installation.
Could you please help me to finish this example?
regards
Janaka
klumsde
is there any issue with write permissions to directories associated with the install?
klumsde
I've installed this GUI before and not seen any issues.
It comes as an executable so all these dependencies should be included.
I can try re-install it here myself.
Do you have labview installed on the machine as well?
janaka
No I don't have Labview on my machine.
I just followed the user guide instructions and installation seemed to be OK but when I open the tool, I get this.
Janaka
klumsde
janaka
I opened the setup file as administrator. So I don't think it was an issue. Should I remove it and re-install ?
klumsde
Maybe remove and reinstall as a last resort. You definitely downloaded this from xilinx.com and not anywhere else? I'll try it on my end. I use windows 7
janaka
I installed it from the link given in the AMS 101 reference design user guide. I removed the installation and reinstalled as the administrator but when I open "AMS 101 Evaluation GUI" it gives the same missing errors. I have a 64-bit machine. does it matter? Does this give any problem for running the reference design? I have not run it yet.
Thankls
Janaka
janaka
Hi klumsde:
Have you found any reason for this? Greatly appreciate any suggestions as |I am stuck at this place.
Many Thanks
Janaka
klumsde
Tried reinstalling it and it works fine on my side.
Have you checked the NI forums and articles on this?
