ARTIX-7: Power-On/Off Power Supply Sequencing for VCCADC / VREFP
according the Artix-7 data-sheet (DS181 (v1.6) April 17, 2013), chapter "Power-On/Off Power Supply Sequencing" on page 5 the sequencing for VCCINT, VCCBRAM, VCCAUX, and VCCO is defined.
What I'm missing is, the sequencing for VCCADC / VREFP? Is there any requirement for the sequencing for VCCADC / VREFP together with VCCINT, VCCBRAM, VCCAUX, and VCCO ?
BR Bodo
Re: ARTIX-7: Power-On/Off Power Supply Sequencing for VCCADC / VREFP
>I assume by VREFP you really mean the VREFP and VREFN supply  pins of the XADC?
Yes, that's correct.
Thanks!
Nope,
Any sequence is just fine for these.
Austin Lesea
Principal Engineer
Xilinx San Jose
can I ground VCCADC and VREFP in case I do  not need the XADC?
The VCCADC pin should be tied to VCCAUX even if the XADC is not being used. The rest of the XADC pins can be tied to GND. I assume by VREFP you really mean the VREFP and VREFN supply  pins of the XADC?
Thanks!
Do we have a dedicated pin for Power on reset in Artix7?
Also do we need any monotonicity for the power supplies?
PROG_B is sort of a power-on reset. And yes, the supplies should rise monotonic. You don't want to have a dip around the POR thresholds for sure.
