Visitor rahuljha08
ARTIX7 IBIS model
I am using the FPGA as a receiver and using the Artix 7 IBIS model. I have to select input pin for LVDS_25 for 2.5V or 3.3 V
Now here, there are two option available for selecting the inputs pins.They are:
1. LVDS_25_HR_I
2.LVDS_25_DT_HR_I
I have attached one screenshot for reference.
Can anyone suggest which model name I have to select.
Re: ARTIX7 IBIS model
Hello @rahuljha08
If you want to use internal differential termination i.e. DIFF_TERM then use LVDS_25_DT_HR_I otherwise use LVDS_25_HR_I.
Check UG471 (v1.10) (Page 91~92) for more details.
Note : Internal differential termination is should be used for inputs only.
Bhushan
