abinaya1991@
AURORA 64B66B
           I am using AURORA 64B66B fo SFP in K7  board(it is for Receiver)..  I am following xapp1212-simplx ..and not clear about  the following(Default from Aurora),
set_property LOC AG14 [get_ports RX_HARD_ERR]
set_property IOSTANDARD LVCMOS18 [get_ports RX_HARD_ERR]
As per my board how to choose this pin and corresponding PIN
My  FPGA: xc7k160tffg676  High Range(HR Type)
smarell
Community Manager
Community Manager
You can assign this to any pin of your choice on your board. If you don't have LEDs on your custom board, you can connect this port to a VIO to monitor it's state.
abinaya1991@
Thanks for your response,
   How to connect this to VIO, I am not aware about this
ashishd
Hello abinaya1991@,
In order to be familiar with VIO core, you can follow steps in below tutorial -
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug936-vivado-tutorial-programming-debugging.pdf
Ashish
smarell
Community Manager
Community Manager
You can check Vivado Lab Tools in Aurora IP customization GUI as shown below to include ILA and VIO cores in the design.
abinaya1991@
So,
      Don't we need to assign the pin in XDC? Shall I remove this line in xdc?
venkata
If you are monitoring RX_HARD_ERR using VIO, you can remove the LOC constraint in .xdc file
abinaya1991@
     After adding the VIO IP in our Aurora example design, How to connect the specification to VIO?
venkata
Please generate IP with "vivado lab tools" option and generate IP example design. You can refer to example code in IP example_design file to know how to use VIO.
