Adding new configuration memory device in Vivado
   I managed to connect the Spartan-7 to Vivado via JTAG with modes pin M[2:0] set at 101. The code runs correctly because I see the IO driving a LED go high.
However, when I try to program the .bin file, I will need to add a new configuration memory device in Vivado hardware manager but I do not see my flash memory listed. All I see is Macronix, Spansion and Micron. How do I add a new flash device? I am using the ISSI part number: IS25LP128F-JBLE-TR
   If I do manage to program the flash with the *.bin file, on the next boot up, I should change M[2:0] to 001, correct?
Thanks!
Hi @vivienwwp ,
Which Vivado version you are using? And also specify OS version?
Can you try with Vivado 2018.3 by installing Lab version? and share the results.
IS25LP128F is not supported.
You can use IS25LP128 Flash.
Please use supported ISSI Flash by referring page 337 of UG908 (v 2018.3)
I tried created BIN file for IS25LP128 Flash in Vivado 2018.3, I was succesfully able to see the flash name IS25LP128 as below:
---------While programming the Flash, Mode pins changing is not neccesary. But after programming, for booting from flash Mode pins needs to be changed.
hope this helps.
Deepak D N
Please reply or give kudo or Accept as a Solution.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @vivienwwp ,
hope this helps.
Deepak D N
Deepak D N
Hi Deepak
  This is great news! I installed Vivado 2018.3 and I did see the flash configuration memory device- IS25LP128. I successfully program the bin file. Then I powered down and changed my MODE pins to M[2:0]= 001 and powered up but it didn't seem to boot from flash. What could be the problem?
 Are bin files generated for a specific flash? How do I specify the type of flash while generating the bin files?
Hi Deepak
  Managed to get it working. I realized I needed to press the pull PROGRAM_B low after programming the flash.
