Affects of Overshoot on Spartan 6 and associated reliability
Due to an oversight, we designed a board with a driver that creates an oveshoot into one of the Spartan 6 I/O pins; typical overshoot is 4.6V with a duration of 4%.  The questions are multiple as we have observed no degradation in the performance of the FPGA over months and an unlimited number of cycles (greater than 10MHz rate) - is there a reliability report that details what damage may occur to the pin (only a single I/O in a somewhat limited I/O application).
Mentor
Mentor
Re: Affects of Overshoot on Spartan 6 and associated reliability
Hi @cdehmelt
I'm sure that it's an absolute maximum rating issue.
You must stick to the rules under proper condition.
Refer page 2 of the following URL.
https://www.xilinx.com/support/documentation/data_sheets/ds162.pdf
Best regards,
Understand.
However, that does not answer the questions about what damage occurs  and how much exposure to an overshoot to initiate the damage (and essentially, how where these limits determined).
