Analog Stimulus file (SIM_MONITOR_FILE) placement.
Hello all,
Where should I place my design.txt file to be read during simulation?
Thank you,
Shruthi.
Hi @shruthi_07
You just need to run the simulation for some more time. I got the signals toggling around at 52000 ns. Attaching the screenshot for your reference.
Thanks,Vijay
Hi @shruthi_07
You can place it the location of your interest and point the path in the module instatitation with the variable SIM_MONITOR_FILE.
Thanks,Vijay
also you can refer to the following document in page 21
http://www.xilinx.com/support/documentation/user_guides/ug480_7Series_XADC.pdf
Hi vijay,
I did exactly the same thing. But still my design wouldn't read my stimulus file.
I use Vivado design suite 2015.4 with Artix7 Basys3 (xc7a35tcpg236-1) tool. I had modified "ug480_7Series_XADC.zip" file according to my device.
Please check the attached file, and help me find the mistake.
Thank you,
Shruthi.
Hi kkn,
The pdf reads, "The XADC primitive also has an attribute called SIM_MONITOR_FILE that points to the analog stimulus file... UNISIM and SIMPRIM models use this text file during
simulation. This is the only way analog signals can be introduced into a simulation of the
XADC."
But after the <Verilog_dir>/data/verilog/src/unisims/....does not have 'SIM_MONITOR_FILE'. Is it a reason for the design to not read the stimulus file?
Shruthi.
Hi @shruthi_07
Thanks,Vijay
Great!!
Can you also tell me what changes I need to make in the code?
Thank you so much,
Shruthi.
I found it.
Thank you so much once again.
That was a great help, Vijay!!
