chirag1@
Application info
I want to know the list of DDR SDRAM ICs copatible for Kintex-7 series, 410, -3 type with 900 pins.
Is there any documents relating to that?
Awaiting your reply..
drjohnsmith
there will be no such list as such
due to the flexibility of the fpga and ever changing memories available,
What I'd suggest you do is run the MIG IP , and look at the options and the documentation supplied.
    some chips are pre implemented, others you can get the settings you need fomr the data sheet of the memory,
chirag1@
Thanks sir..
