Visitor bitfiddler
Artix-7 LVDS Clock Input HR Bank with VCCO=1.8V
I have a clock coming from a 2.5V LVDS clock buffer (http://www.onsemi.com/pub_link/Collateral/MC100EP210S-D.PDF) that I would like to use within the FPGA.
The clock is connected to CC pins in the HR bank on the Artix-7 with VCCO=1.8V.
Since HR banks only support LVDS_25, which require the VCCO to be at 2.5V, I have added an external termination resistor.
Questions:
Is it ok to directly connect the output of the clock buffer to the HR bank?
Do I need to add AC couple capacitors and DC bias resistors at the input of the FPGA?
Re: Artix-7 LVDS Clock Input HR Bank with VCCO=1.8V
 > Since HR banks only support LVDS_25, which require the VCCO to be at 2.5V
This is true output, but inputs can be any VCCO from 1.5 to 3.3V in HR banks, except for the following case...
Yes, the use of the internal DIFF_TERM feature requires that VCCO is 2.5V in the HR bank so you need to add the external resistor.
Yes, because the absolute voltage that the input pin will see will not exceed your VCCO of 1.8V.
No, just the differential termination resistor.
Visitor bitfiddler
Please look in UG471at the table Vcco and Vref Requirements for Each Supported I/O Standard.
Note 1 answers your questions:
  • Differential INPUTS for LVDS_25 standard can be placed in banks with Vcco levels that are different from the required level for outputs.
  • In some cases it might be necessary to provide an external circuit to both AC-couple and DC-bias the pins.
Eze
Visitor bitfiddler
Thank you very much.
