Artix-7 -MIPI CSI Interface for High Speed Interface
We are using Artix-7 XC7A200T and interfacing with COM Module from Raspberry Pi and it does support CSI Interface, we want to have high speed interface with COM module in future days through MIPI CSI.
Can you please suggest about supported CSI pin outs available in XC7A200T and recommendations.
Thank you.
Hello @Hemalatha
Artix-7 FPGA do not have I/O which can natively support MIPI D-PHY. So, you need to refer XAPP894 (v1.0) for D-PHY Equivalent solution : Specifically Page 14 to 20.
Refer Appendix C from PG202 (v4.1) for guidelines on pin assignment and bank rules.
Your post is duplicated : https://forums.xilinx.com/t5/Other-FPGA-Architecture/MIPI-CSI-in-Artix-7-for-Data-Communication/td-p/1098557
Bhushan
