Artix 7 QSPI Configuration Flash Selection
I am designing a board with Artix 7 P/N XC7A200T-3FBG484E.
I want to configure the FPGA with 128Mbit QSPI NOR flash in Master SPI mode. I power this bank (bank 0) with 1.8V.
Where can I find information regarding which parts can I use to configure?
Shay
Tags (3)
HI @shay12,
since you;re trying to configure through the SPI flash  AS LONG THE TOOL SUPPORTS there is no issue once check this application note https://www.xilinx.com/support/documentation/application_notes/xapp586-spi-flash.pdf
 and
S.chandra sekhar
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Hi @shay12,
looking for the which part to be used for configuration please refer below link for more info   and UG 908 (https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug908-vivado-programming-debugging.pdf)Table C-1: Supported Flash Memory Devices for Artix-7 Device Configuration page number 317
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/pim_r_supported_spi_bpi_proms.htm
Chandra sekhar
Hi @csattar,
Thank you for the information. I have a follow up question:
Regarding table C-1 of UG908, most of the flash parts are 3.3V I/O. I don't have in my board a 3.3V rail (only 1.8V for IOs).
Can I take the same basic flash P/N with 1.8V IO?
For example in the table we see Cypress basic P/N S25FLXXXS (3.3V). Can I use S25FSXXXS (1.8V)?
Shay
hi @shay12,
thanks for the reply , can i know which tool and FPGA device your using , also the configuration method .Is there any requirement to use only 1.8 .or any cost effect solution
thanks
Sekhar
Chandra sekhar
@shay12 Can I use S25FSXXXS (1.8V)?
I don't think there is any 1.8 Spansion flash supported. You could consider using 1.8 Micron flashes.
Micron N25Q 32, 64
mt25qu128
Supported by tools :)
-Pratham
Hi Sekhar ,
I am using XC7A200T-3FBG484E.
My design tool will be Vivado.
I want to configure in master SPI mode.
The 1.8V only power rail is an heritage from same board with LX150 FPGA (which worked with 1.8V SPI flash and Impact)
Shay
HI @shay12,
 and
S.chandra sekhar
Chandra sekhar
