pgigliotti_usac
Artix 7 channel pins versus ADC conversion
I am having a hard time finding a document that correlates the channel converted versus the channel pin.  In other words, when the internal temperature  conversion is complete and its digital value is available what well the channel number be.  I am using the wizzard to create the core and want to be able to capture several of the conversion (including several Vaux channels).  I am expecting that the channel pins will indicate which value is being output.  It does not appear to be in UG-480.
pgigliotti_usac
I found the information on page 45 of the UG.  It looks like the document had been updated and the format of the table changed, and thus was different than what I was looking for. Glad it wasn't a snake.
pgigliotti_usac
