adoobii
Artix -7 current limiting
Hello
I am trying to attach a DC motor to the high and low signals provided ny the Pmod ports, but when I do that the FPGA shuts down, does that have to do with the current through the ports?
maxdz8
You can bet. Digital ports are usually in the range of milliamps you'll need at least one transistor (but for big motors I'd suggest two, or one transistor + one relay) to pull serious current.
As far as I understand, most pins from FPGA can barely drive a led. The arty Z7 I have doesn't drive leds directly but goes through a transistor.
maxdz8
adoobii
oh, so I must have an outside power source. I thought I could make the motor work using the FPGA only. Thanks!
