Artix7 Differential pair pullup / pulldown fail in Vivado
Hi ,
The RTL code is very simple.
module blvds_test(
input dp,
input dn,
output rx
  IBUFDS #(
      .DIFF_TERM("FALSE"),       // Differential Termination
      .IBUF_LOW_PWR("TRUE"),     // Low power="TRUE", Highest performance="FALSE"
      .IOSTANDARD("LVDS_25")     // Specify the input I/O standard
   ) IBUFDS_inst (
      .O(rx),  // Buffer output
      .I(dp),  // Diff_p buffer input (connect directly to top-level port)
      .IB(dn) // Diff_n buffer input (connect directly to top-level port)
     PULLUP PULLUP_inst (
      .O(dp)     // Pullup output (connect directly to top-level port)
     PULLDOWN PULLDN_inst (
      .O(dn)     // Pulldown output (connect directly to top-level port)
endmodule
Get following warning message :
[Constraints 18-4379] The N and P sides of the following differential port(s) have connections to PULLUP/DOWN primitives that conflict with the setting of iconstr.diffPairPulltype param.  The PULLUP/DOWN connection for these ports will be ignored. dn, dp
I checked the IO properties,PULLUP on both dp and dn.
Kim
Re: Artix7 Differential pair pullup / pulldown fail in Vivado
@kimwen From Vivado 2014.1 Vivado implementation we have changed the way.
If you would like to keep pullup/pulldown on diff pairs this is controlled by param called iconstr.diffPairPulltype param.
if you would like to keep pullup on p and pulldown on n just set this parm to opposite by setting Pullup on P port.
lets take your example here
module blvds_test(
input dp,
input dn,
output rx
  IBUFDS #(
   ) IBUFDS_inst (
endmodule
Please note i have removed pulldown from above code. now before running this code just run this tcl command in vivado tcl console
set_param iconstr.diffPairPulltype opposite
Above tcl command would set the opp pulltype on N port. After running impl you would see Pull up on P and Pul down on N
-Pratham
module blvds_test(
input dp,
input dn,
output rx
  IBUFDS #(
   ) IBUFDS_inst (
endmodule
-Pratham
@kimwen Did that help?
-Pratham
Hi Pratham,
Thank you for your kindly help.
The solution is working for me.
Kim
