07-31-2014 12:42 PM
I'm getting the following message:
[Place 30-574] Poor placement for routing between an IO pin and BUFG. If this sub optimal condition is acceptable for this design, you may use the CLOCK_DEDICATED_ROUTE constraint in the .xdc file to demote this message to a WARNING. However, the use of this override is highly discouraged. These examples can be used directly in the .xdc file to override this clock rule. < set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets fsync_IBUF] > fsync_IBUF_inst (IBUF.O) is locked to IOB_X1Y99 and fsync_IBUF_BUFG_inst (BUFG.I) is provisionally placed by clockplacer on BUFGCTRL_X0Y16
I was hoping I can get a better explaination of this error. When i use the CLOCK_DEDICATED_ROUTE FLASE property I can remove the error but I would like to know that my deisgn will still function.
Does it think that my fsync is a clock? I was using some edge detect statements on that signal which might be confusing the tool.
Thanks for your help.
-J
07-31-2014 01:21 PM
Honestly I'm surprised that this code actually synthesized. It's not clear what you were trying to describe by (not falling_edge(fsync)) since it means "any time the signal fsync is not transitioning from high to low." I don't know of any hardware that matches this behavior. It would be interesting to see what the synthesizer did with this. In any case I suspect it's not what you wanted. If fsync is a relatively slow signal (frame sync?) then normally you should use a flip-flop to delay it and detect the falling edge by the signal being high on one clock cycle and low on the next.
07-31-2014 12:46 PM
If the tools have placed a BUFG, it generally means the signal has clock loads. Note that the gate of an inferred latch is also considered a clock load. If you don't have any synthesis warnings about latches, then my guess is that the signal is a clock because of the "edge detect statements" in your code. If you want to post the relevant code, I could possibly comment further.
07-31-2014 12:50 PM
Here is the body of my RTL. Any additional insight would be great.
architecture main of f_grab is begin process(pclk, fsync) begin if(not falling_edge(fsync)) then fsync_out <= fsync; lval_out <= lval; dval_out <= dval; data_out_base <= data_base; data_out_full <= data_full; end if; if(falling_edge(fsync)) then fsync_out <= '1'; lval_out <= '1'; dval_out <= '1'; end if; pclk_out <= pclk; end process; end main;
07-31-2014 01:21 PM
07-31-2014 01:40 PM
The behavior i'm looking for us when fsync (frame sync) goes low i keep it high within the fpga and add in an extra line of information. After the line is added I then bring fsync low.
-J
07-31-2014 01:54 PM
Perhaps something more akin to this:
if(fsync='0' and reg_fsync='1') then fsync_out <= '1'; lval_out <= '1'; dval_out <= '1'; else fsync_out <= fsync; lval_out <= lval; dval_out <= dval; data_out_base <= data_base; data_out_full <= data_full; end if; pclk_out <= pclk; reg_fsync <= fsync;
07-31-2014 02:06 PM
This now implements without error
