mushihao
Async fifo timing violations using FIFO generator
I am using vivado 2020.1 and FIFO generator 13.2. I implemented "independent clocks built in FIFO" with write data width 1024 and read data with 512. I feed write clock 200MHz and read clock 400Mhz in the design. However, I always got a lot of timing violations on the path from EMPTY to RDEN. Has anyone seen such issue before and any suggestion on it?
Hao
drjohnsmith
without knowing the device your targeting, or the timing constraints your using, or the error reports, not much we can say,
bruce_karaffa
You say the timing violation is from EMPTY to RDEN, not from your read clock to RDEN.  Does this mean that the RDEN signal does not come directly from a register?  At 400MHz, this may be a problem.  How many levels of logic are between a clocked register and the RDEN signal?
mushihao
Oh, I think you are right. The source of the violation path is RDCLK and the destination is RDEN. The violation datapath is shown as:
...gonep.inst_prim/gf36e2_inst.sngfifo36e2/EMPTY
...gonep.inst_prim/gv.gv3.VALID_reg_2[0]
...gonep.inst_prim/empty_INST_0_i_4/O
...gonep.inst_prim/rd_clk_1
...gonep.inst_prim/gf36e2_inst.sngfifo36e2_i_l_rewire_rewire_replica/O
...gonep.inst_prim/RD_EN_repN_alias
...gonep.inst_prim/gf36e2_inst.sngfifo36e2/RDEN
I actually tied the rd_en of the fifo inst to 1'b1. So I am wondering why there is still a violation. Any idea?
Hao
mushihao
Sorry, I am using VCU128 dev board now. Thanks!
