Anonymous
Not applicable
Beside BLVDS can support bi-directional transfer ,What kind of IP can do this like BLVDS?
Base on chip "XC7K70T". We design 8 path video processing(input/output is selectable by user but with the same one FPGA code). Cause by too much channel,we need to combine data as serier type, and also need high speed bidirection transfer module like BLVDS. Unfortunately, it's max. speed is only 200MHz. We need more than 300MHz speed(with max. pair of signal pins). Is there any other IP module we could use to achieve this requirement?
By the way,we know GTX port,but we are looking for the other solution.
