Best Output Clock Generation Method
Hi to all,
I am designing for Kintex 7 and I need to generate a perfect output 100MHz clock. Currently, I am generating it using ODDR2 but it has some jitter.
What is the best way to do that?
Thank you very much in advance.
Kindest Regards,
Amir
@amir.massah
You’ll find lots of discussion and some test results about jitter of clocks created by a 7-Series FPGA in the following thread.
https://forums.xilinx.com/t5/Other-FPGA-Architectures/FPGA-creates-main-clock-for-ADC/td-p/857807
Mark
what do you mean by perfect ?
ODDR2 is the way to do it,
the limiting factor is going to be what are you driving the clock to the ODDR2 with,
Be certain to use a PLL, and use the low jitter output option,
What is the jitter your getting ?
Can you post screen shot from the scope or spectrum analyser your using to measure this,
Ultimately, FPGAs are not the best way of generating a clock for something like and ADC.
If its is an ADC your driving, whats the number of bits and analog bandwidth of the ADC,
Hi @amir.massah
What criteria does "a perfect output 100MHz clock" mean ?
Perfect duty ? Less clock jitter ? Need to concern variation ?
If my understand is correct, I suggest you to make sure a clock source of ODDR2.
Best regards,
Hi to all,
I mean low jitter and 50-50 duty cycle by perfect.
For my clock source, I am using PLL and the with enabled optimum output jitter option.
Kindest Regards,
Amir
