Board definition files
I want to create board definition files for a new board. I got some BDF files for another board not in my vivado install and copied the content into the <Vivado>/data/boards/board_files folder.
Started Vivado, went to create a new project, choose 'board' instead of 'part' and the new added board is there.
Now, I copy-paste that folder and rename it for my board. Open the board.xml file and do basically cosmetic changes (board name, vendor name, description, etc) and change the part number. I alse delete interfaces and components.
Start Vivado again (I know it has to be closed to re-read the board files), start a new project, but my board is not listed...
Why?
Re: Board definition files
It looks like the part number has to have the right syntax and it has to match in both the board and part0_pins files. It's fine now.
