Visitor schroeca
CSI2 interfacing
i want to connect a CSI2 D-PHY compliant imager directly to the FPGA. In the I/O specification it is stated, that the differential voltage on the input (Vid: Q-nQ) should not be higher than 600 mV.
In the CSI2 specification it is mentioned that a receiver must be capable of handling a voltage of 1.3V max. This is necessary to detect a start condition for an high speed transmission.
To handle this case the standard recommends to en/disable the differential termination. But this is not possible with the FPGA.
Is there any recommendation on how to connect to an CSI2 D-PHY compliant IC?
Is it allowed to have a differential voltage of 1.3V for a short period of time? In my case this would mean a current of 13mA flowing across the internal diff_term.
Tags (3)
Teacher muzaffer
Re: CSI2 interfacing
Check out this document; http://www.edn.com/design/communications-networking/4368073/Implementing-an-SLVS-transceiver
it might help.
