Can mode pin selection be changed after configuration
In my design, the kintex-7 FPGA are configured by master SPI mode on powering up. After it. a MCU should be configue it in slave serial or slave selectmap mode. The mode pins are tied to low and high using pull-down or pull-high resistor. The mode pins are also connected with MCU.I plan put MCU pins to the float state at powering up. After it, when it need to configure FPGA, it change the mode pin setting. However, I found "The mode pins should not be toggled during and after configuration." in the last paragragh of page 11 of 7 series FPGAs configuration user guide.Please tell me whether my plan will work. Thank you.
Re: Can mode pin selection be changed after configuration
Greatmaverick,
Mode pins are only used/sampled during the initialization stage of configuration. On the rising edge of INIT_B to be exact. After configuration you should be able to change them without any issues. Of course you need to reconfigure the device to make use of the new mode pin selection. If you have a Xilinx development board of any kind this would be an easy test to do.
Tezz
Greatmaverick,
Tezz
