Voyager
Voyager
Choosing correct pinlocks for required interfaces ?
Hi Friends,
We purchased Kintex FPGA part, and we have different interfaces like UART, SD, DDR, USB etc. How to choose correct pin assignment with respective to interface. For DDR we have MIG, is there anything like that for all interfaces ?
NOTE: Any help or suggestions are highly appreciated.
Thank You
S Sampath
回复: Choosing correct pinlocks for required interfaces ?
hi @ssampath
You can do pin Planning first.
Below is the document.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug899-vivado-io-clock-planning.pdf
Boris
Scholar drjohnsmith
Re: Choosing correct pinlocks for required interfaces ?
Dont know which part you have,
but general pointers.
If it has a built in ARM ( a Zynq 7 part )
     and you want to use the peripherals of the Zynq, then pins are a prescribed.
If your in the FPGA, making your own peripherals,
   then things are a lot more open.
Clocks into the device has special pins,
   configuration pins are special
Generally, Memories are fairly constricted on where they can be connected and how,
     due to speed and voltages, and special bits in the chip that help you
  other ports you mention are basically constrained by voltages of the IO
      dont mix say 1v8 and 3v3 IO,
