Clamping Diodes On I/O Pins
UG331 indicates on p.335 that Spartan-3A devices do not have clamping diodes enabled (typically) connecting I/O pins to their Vcco power input.
What other FPGA and CPLD families, if any, provide a similar capability?
Hello @chsdkj
Spartan-6 devices do not have clamp diode to VCCO. .
If you are looking for hot swapping of FPGA, please go through following links:
Bhushan
Hello @chsdkj
Bhushan
