DCM and MMCM
Are the Locked Outputs for both similar ?
I read from another thread, here , where it was suggested to alternatively use the LOCKED output of an MMCM in the implementation of a reset.
I'm curious as to whether this will work in DCMs too
Yes, they are the same. You can use the locked output of DCM as reset, too. It has a same behavior and it says the clock is ready and stable. So it can be used as an active-low reset.
Reply if you have any queries, give kudos and accept as solution.
yes
sorry for getting back late. But i tried and it worked! Thanks a lot.
