muuu
DDR3 termination(ARTIX-7 XC7A35-FGG484)
 we design a ddr3 board and use Fly-by routing topology, should a 40Ω pull-up to VTT at the far end of the linebe used? we didn't find DDR Termination Regulator and 40Ω pull-up to VTT on some evaluation board, why?
Best regards,
Muuu
watari
Hi muuu
Could you show me your circuit diagram, if possible ?
Do you use an external DRAM chip ?
If yes, you don't need 40ohm pull-up to VTT.
Because you don't need to control CS of DRAM...
Thank you.
Best regards,
muuu
we use DDR3 CHIP MT41J128M16JT-125 on the board, not RDIMM or UDIMM.
gszakacs
Instructor
Instructor
For a fly-by topology, the address, control, and clock signals should all be terminated to Vtt at the end of the route farthest from the FPGA.  DQ and DQS signals use on-die termination and don't require board-level termination to Vtt.  The only reason a board may not implement board level termination on address or control signals is that the routes are very short (less than 1 inch typically).  Do you have a link to the evaluation board you found without Vtt termination?
-- Gabor
muuu
trenz-al
with single IC DDR component all terminations except for CLK can be ommitted fully.
Interesting... Is this true for any data rate (1600MT/s +)? or is it for the ARTIX (800 MT/S)? Thanks.
