Scholar vanmierlo
[DRC REQP-107] enum_IOBDELAY_BOTH_enum_IOBDELAY_IBUF_connects_O
I have several ISERDESE2's configured for 14 bit deserializing with IDELAYE2's to align against the incoming clock.
To use the IDELAYE2 as input to the ISERDESE2 the manual (UG471) says I should configure IOBDELAY as either IFD or BOTH. But IFD is apparently not allowed in MASTER-SLAVE configuration:
[DRC PDIL-1] Invalid Site Configuration: Invalid configuration for site ILOGIC_X0Y72. Reason: Site pin to site pin route-thru requires conflicting attribute enum values for user logic element 'ISERDESE2 in site 'ILOGIC_X0Y72'. Attribute 'IOBDELAY' is programmed to 'IFD' but needs a value of 'BOTH' for the route-thru.
However, when I choose BOTH implementation Write Bitstream DRC Required Pin gives this warning:
[DRC REQP-107] enum_IOBDELAY_BOTH_enum_IOBDELAY_IBUF_connects_O: The O output pin is required for IOBDELAY set BOTH or IBUF.
Yet I have no use for the O output. I only need the Q1-Q8 outputs.
Am I supposed to tie off the O output somewhere, and if yes, where and how?
Maarten
Community Manager
Community Manager
Re: [DRC REQP-107] enum_IOBDELAY_BOTH_enum_IOBDELAY_IBUF_connects_O
Hi @vanmierlo
if you are using the 14-bit deserialing you are using both the P and N side ISERDES with the width expansion. The error message is about a route-thru so I'm wondering if it is actually complaining about the N side not the P side (where you need outputs [8:13]). Can you check if the ILOGIC_X0Y72 is for the P side or the N side?
Are you using a IBUF or an IBUFDS on the P/N pair?
You should have one IDELAY instantiated before the ISERDES's. The IDELAY on the N side would then be a route-thru.
Can you share the snippet of code of how the IDELAY/ISERDES are instantiated?
Sandy
Scholar vanmierlo
The warning is about the ISERDESE2 configured with SERDES_MODE = "MASTER". I have no idea if that is the P side or the N side. There is no warning about the ISERDESE2 configured as "SLAVE".
The input comes from lvds pairs going through an IBUFDS and an IDELAYE2.
	buf : IBUFDS
	port map (
		I		=> lvds_clk_p,
		IB		=> lvds_clk_n,
		O		=> unipolar_clk
	dly : IDELAYE2
	generic map (
		SIGNAL_PATTERN	=> "CLOCK",
		IDELAY_TYPE	=> "VARIABLE",
		IDELAY_VALUE	=> INIT_CLK
	port map (
		C		=> clk,
		CE		=> inc_delay_clk,
		LD		=> io_reset,
		LDPIPEEN	=> '0',
		REGRST		=> '0',
		CINVCTRL	=> '0',
		CNTVALUEIN	=> INIT_CLK(4 downto 0),
		INC		=> '1',
		CNTVALUEOUT	=> value_clk(4 downto 0),
		DATAIN		=> '0',
		IDATAIN		=> unipolar_clk,
		DATAOUT		=> clock_i
	buf_clk : BUFIO
	port map (
		I	=> clock_i,
		O	=> clkin
	clkb <= not clkin;
	div_clk : BUFR
	generic map (
		BUFR_DIVIDE => "7"
	port map (
		CE	=> '1',
		CLR	=> clk_reset,
		I	=> clock_i,
		O	=> clk_div
	channels : for I in 0 to WIDTH - 1 generate
		buf : IBUFDS
		port map (
			I		=> lvds_p(I),
			IB		=> lvds_n(I),
			O		=> unipolar(I)
		dly : IDELAYE2
		generic map (
			IDELAY_VALUE	=> INITS(I)
		port map (
			C		=> clk,
			CE		=> inc_delay(I),
			LD		=> io_reset,
			LDPIPEEN	=> '0',
			REGRST		=> '0',
			CINVCTRL	=> '0',
			CNTVALUEIN	=> INITS(I)(4 downto 0),
			INC		=> '1',
			CNTVALUEOUT	=> values(I)(4 downto 0),
			DATAIN		=> '0',
			IDATAIN		=> unipolar(I),
			DATAOUT		=> data_i(I)
		serdes_lsb : ISERDESE2
		generic map (
			DATA_RATE	=> "DDR",
			DATA_WIDTH	=> 14,
			INTERFACE_TYPE	=> "NETWORKING",
			IOBDELAY	=> "BOTH",
			SERDES_MODE	=> "MASTER"
		port map (
			RST		=> io_reset,
			CLK		=> clkin,
			CLKB		=> clkb,
			OCLK		=> '0',
			OCLKB		=> '0',
			CLKDIVP		=> '0',
			DYNCLKSEL	=> '0',
			DYNCLKDIVSEL	=> '0',
			CE1		=> '1',
			CE2		=> '1',
			OFB		=> '0',
			D		=> '0',
			DDLY		=> data_i(I),
			SHIFTIN1	=> '0',
			SHIFTIN2	=> '0',
			SHIFTOUT1	=> shift1(I),
			SHIFTOUT2	=> shift2(I),
			CLKDIV		=> clk_div,
			BITSLIP		=> bitslip(I),
			Q1		=> data(I)(0),
			Q2		=> data(I)(1),
			Q3		=> data(I)(2),
			Q4		=> data(I)(3),
			Q5		=> data(I)(4),
			Q6		=> data(I)(5),
			Q7		=> data(I)(6),
			Q8		=> data(I)(7),
			O		=> open
		serdes_msb : ISERDESE2
		generic map (
			DATA_RATE	=> "DDR",
			DATA_WIDTH	=> 14,
			IOBDELAY	=> "NONE",
			SERDES_MODE	=> "SLAVE"
		port map (
			RST		=> io_reset,
			CLK		=> clkin,
			CLKB		=> clkb,
			OCLK		=> '0',
			OCLKB		=> '0',
			CLKDIVP		=> '0',
			DYNCLKSEL	=> '0',
			CE1		=> '1',
			CE2		=> '1',
			OFB		=> '0',
			D		=> '0',
			DDLY		=> '0',
			SHIFTIN1	=> shift1(I),
			SHIFTIN2	=> shift2(I),
			CLKDIV		=> clk_div,
			Q3		=> data(I)(8),
			Q4		=> data(I)(9),
			Q5		=> data(I)(10),
			Q6		=> data(I)(11),
			Q7		=> data(I)(12),
			Q8		=> data(I)(13),
			O		=> open
	end generate;
Community Manager
Community Manager
Hi @vanmierlo
I took the snippet of code and implemented it in Vivado 2019.1
When I used IFD I get no DRC.
When I used Both I get the DRC, which is expected when you are not using the O port.
I tried swapping the P and N sides to see if I could reproduce the issue but Vivado tells me that it can't assign them incorrectly
[Vivado 12-1411] Cannot set LOC property of ports, the positive port (P-side) 'lvds_p[0]' of a differential pair cannot be placed on a negative package pin 'AM11' (IOBS). ["/home/sandrao/cases/ISERDES_Forum/project_2/project_2.srcs/constrs_1/new/Temp.xdc":285]
Do you want me to send you the testcase with your code?
Sandy
Scholar vanmierlo
For "IFD" the error comes in Write Bitstream. That is after Implementation already passed.
Community Manager
Community Manager
Hi @vanmierlo
My testcase of your code passing write_bitstream for the IFD.
What version of Vivado are you using?
Would you like me to send you my testacase?
Sandy
Scholar vanmierlo
I'm using Vivado v2019.1 on linux. I'm targeting a Zynq 7010.
Yes, now I'm getting curious how you got this to work. So please send me your testcase.
