Data tranfer form 7 series(kintex-7) FPGA to PC via Ethernet
    I need to transfer data from kintex-7 FPGA to PC via Ethernet around 80 Mega bits of data per second, as well as need to receive some control signal from PC to FPGA (just contro signal) , litterally i do not how how to start. (either UDP/ TCP protocal) ,
and what is format to send data,suggest me if there is any IP to do this
dpaul24
narendrandesainath@gmail.com,
Similar question answered in this thread: https://forums.xilinx.com/t5/Networking-and-Connectivity/How-to-use-MAC-address-of-FPGA-to-communicate-with-Ethernet-PHY/m-p/953682#M15529
Search around and READ ALL DOCS......is the bottom line!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
Asking for solutions to problems via PM will be ignored.
