Decoupling Capacitor for MGT of Kintex
To whom it may concern,
Does Kintex-7 FBG676 package has discrete substrate decoupling capacitors for MGT power supplies?
If that is the case, can I avoid the decoupling capacitors for MGTAVTT, MGTAVCC and MGTVCCAUX on PCB?
回复: Decoupling Capacitor for MGT of Kintex
Hi @serm_wang
Those substrate package capacitors is helping maintain a low impedance, high-frequency path between power supply and ground, and noise attenuation in the package
Simon
Hi @serm_wang
Yes, it has, but PCB capacitors are recommended to provide noise isolation between the transceiver power supply pins and the external noise sources, table 5-6:
https://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf
Simon
Hi Simon,
Thank you for your prompt response.
There are quite a few decoupling capacitors on substrate of FB package, what is the purpose for those discrete substrate decoupling capacitors?
Hi @serm_wang
Simon
