Decoupling capacitor network for Artix-7 design
Dear all,
I know that there have been several posts on the subject but I still did not find the answer.
I am working on a Artix-7 () based design and I am wondering what it the best strategy for the decoupling capacitor network. I have read the UG483. However, when I look to the  Avnet Artix‐7A50T (XC7A50T‐1FTG256C) and AC701 (XC7A200T-FBG676) evaluation boards I see that the number of capacitors does not meet the guidelines.
As an axample for the XC7A200T-FBG676 Vccint, the UG483 suggests 1x680uF, 12x4.7uF, 14x0.47hF. However, on the AC701    they use  1x680uF, 2x100uF, 28x4.7uF.
Is there an explanation?
m,
The recommended capacitors (values, number) are intended for those who do not know what they will do with their board, and is a solution for most applications.  Some applications may actually require more.  Most it will be over-kill.
If you know what you are going to do with your board, have a power analysis provided by the tools, and know how to use a power integrity design tool, then you may build your own networks, choose your own values.  Most of our major customers do just that.
I cannot speak for Avnet, but they certainly do have the tools, and the skill to design the power distribution network for the intended applications they are serving with a board.
Austin Lesea
Principal Engineer
Xilinx San Jose
On Package Capacitor information will most likely be published with decoupling guidelines in the 7 Series FPGAs PCB Design and Pin Planning Guide.
Most of the mechanical drawings and pin-lists are currently available in UG475 -7 Series FPGAs Packaging and Pinout Specifications. In addition, most current package files (.pkg) can be generated through the most current version of IDS tools using the partgen -v command.
For packages not listed in UG475 or packages listed with no drawings / pin lists / on-package capacitors, the following is just a guidance on when information will be made ready. This is subject tochange.
To derive estimatedschedulesof drawings / pin lists, use the following instructions:
  1. Look for Order Entry Date for Initial ES in the 7 Series Monthly Update. (On SPW)
  2. If the package in question is listed with the Order Entry Date, subtract 6 weeks from the last day of the quarter or month listed
  3. The resulting date is an estimate you can share with the field contact or EA customer.
  4. If the package in question is not listed with the Order Entry Date, subtract 6 weeks from the last day of the quarter / month in the General ES column
  5. The resulting date is an estimate you can share with the field contact or EA customer.
For example, if you are looking for XC2000T FL1925, look for the Virtex-7 Silicon updates section of the 7 series Monthly update. Since the Initial ES column does not list this package, go with the date in the General ES column. Subtract 6 weeks from the last date of CYQ2'12 (note: this was from the July 2011 update).
you can also check
http://www.xilinx.com/support/answers/43204.html
The user guide provides all details about how to connect unused GT I/Os. A floating I/O is needed on development boards because any GT I/O must be accessible for tests and measurements. If a particular GT is not used, this seems to be in contrast with UG recommendation.
The user guide also suggests to ground unused GT I/Os because this is a "good design" practice. Of course, an I/O that is floating or (that is a similar condition) connected to decoupling capacitor will not break just because it is floating.
Thanks and Regards
Balkrishan
thanks for your reply. However, I can't find the answer to my question.
Cheers
I think information given in UG483
http://www.xilinx.com/support/documentation/user_guides/ug483_7Series_PCB.pdf
Thanks and Regards
Balkrishan
Exaclty, when I look at tthis table and then I check the two eval boards schematics I realise that the number of capacitors used does not match:
The same for the AC701 Eval board.
@matte_dc Evaluation board schematics are for just a refrence, i would recommend you to please follow UG483 recommendations no matter whats their in schmatics.
if you would like to know more please open a service request on this issue.
-Pratham
To understand why the difference in the actual implementation, you can read through the theory  - http://www.xilinx.com/support/documentation/application_notes/xapp623.pdf
The main aim is to cover different frequency ranges where the impedance is the least. In general the recommendation is to use the supported capacitors given in the UG. However you have to do the final power integrity simulations, to check how the impedance profile looks like.
Sometimes if the capacitances are not available, you can use alternate capacitors but there are recommendations for these too.
Check the foot note of Table 2-4 of the below link
Anirudh
PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.
m,
Austin Lesea
Principal Engineer
Xilinx San Jose
Professor
Professor
Very good advice!  Often the reference designs were based on boards used to "bring up" new parts before they were fully characterized.  The numbers in the User Guide tables are based on the latest characterization data.
-- Gabor
Thank you all for your answers.
PDN decoupling is not a simple equation. as it has been pointed here it depends on the board usage, as well as the geometry and stack-up. Even with the same usage, two boards may behave differently. On top of that, capacitors, when we use them for decoupling, the least important parameter is their capacitance. We look for small ESR and ESL, basically. And there is also some extra inductance depending on the vias location next to each capacitor.
summing it all up, the way I'd suggest for decoupling is to use some PDN analysis simulation tool. If that's not available, common sense rules may produce a working board after a few loops.
