06-19-2018 04:54 PM
I have a global clock input as follows:
module MySystem( [...] input wire PIN_PCB_CLK, [...] ); [...] wire CLK_PCB; // this is used as a clock and other clocks are derived from it wire clk_1x; // buffered version of input clock PIN_PCB_CLK wire clk_2x; // optional 2x division // buffer input IBUFG clk_pcb_buf( .O(clk_1x), .I(PIN_PCB_CLK) ); // clock divider clk_wiz_v3_6 clk_wiz_v3_6(.CLK_IN1(clk_1x), .CLK_OUT1(clk_2x)); // select either 1x or 2x clock for CLK_PCB // cfg1 is a control register BUFGMUX clk_pcb_mux( .O(CLK_PCB), // Clock MUX output .I0(clk_1x), // Clock0 input .I1(clk_2x), // Clock1 input .S(cfg1[0]) // Clock select input );
To account for relative timing outside of the FPGA, I would like to relatively delay everything that happens within the FPGA. The clock can be up to ~80-100 MHz so adding a delay in the ns range (maybe even below) would be great.
What is the simplest way to achieve this?
Similarly as the S input of the BUFGMUX in the above code, I would like to have this delay software programmable via a configuration register.
I heard about IODELAY2 but I cannot find any information how to instantiate it properly.
06-19-2018 08:46 PM
Hi @nhs
You can use the digital clock manager to phase shift a clock signal, either by a fixed fraction of a clock period or by incremental amounts.
You can get the more detailing of this in Spartan-6 clocking user guide
https://www.xilinx.com/support/documentation/user_guides/ug382.pdf -> Page 59.
IODELAY2 primitives are use to delay the data signals. you can find the IODELAY2 detailing in spartan-6 selectIO user guide
https://www.xilinx.com/support/documentation/user_guides/ug381.pdf -> page 72
and instantiations template in Spartan-6 Libraries user guide
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/spartan6_hdl.pdf -> page 137
Reply if you have any queries, Give Kudos and accept as solution
06-19-2018 08:46 PM
Hi @nhs
06-21-2018 02:13 PM
Great! I just modified my clz_wiz appropriately:
wire PSDONE; clk_wiz_v3_6 clk_wiz_v3_6( // Clock in ports .CLK_IN1(PIN_PCB_CLK), // IN // Clock out ports .CLK_OUT1(clk_1x), // OUT .CLK_OUT2(clk_2x), // OUT // Dynamic phase shift ports .PSCLK(ti_clk), // IN .PSEN(PSEN), // IN .PSINCDEC(PSINCDEC), // IN .PSDONE(trigger_out[0]) // OUT ); BUFGMUX clk_pcb_mux( .O(CLK_PCB), // Clock MUX output .I0(clk_1x), // Clock0 input .I1(clk_2x), // Clock1 input .S(cfg1[0]) // Clock select input );
which internally uses the clock manager. Unfortunately I do not really have a way to verify at this moment but it seems the right thing so I mark as solved :) Thanks again!
