rajanbedi
Delaying output data from a Kintex 7 410T FPGA
Does anyone know:
1. What is the range of the delay (in ns/ps) which the Kintex 7 410T FPGA can delay output data with respect to
an input clock?
2. What is the range of the jitter which the Kintex 7 410T FPGA adds to output data?
Thank you,
Rajan.
rajeshkhanna
please go through the following user guide. (idelay,odelay)
https://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
there is fixed tap delay which can be selected. (max 32 levels)
rajanbedi
The datasheet states that outputs can be delayed by up to 32 increments of 78/52 or 39 ps which is fine for my application.
I'm still searching for how much jitter would be present in the outputs and by how much this would be reduced when HIGH_PERFORMANCE mode is enabled.
