11-13-2018 08:21 AM
I would like to know the difference between the XC7Z020 and XQ7Z020 devices.
Is it only the lead concentration in the solder interface ?
And is the XQ7Z020 radiation hardened ?
Thanks by advance.
Best regards
11-14-2018 08:21 AM - edited 11-14-2018 09:56 AM
Seb_pdr,
Aside from the difference or pluses listed above which are mostly environmental robustness for which they need to be in an "Mil/Aero" conditions, they are the same silicon... If you need more convincing, they use the same data sheet...
Tezz
11-13-2018 09:02 AM
Hi @seb_pdr
Main difference is temperature range between XC7Z020 and XQ7Z020 devices
For more details check DS187 (v1.20.1).
XQ7Z020 devices are defense grade FPGA's.
Bhushan
11-13-2018 09:14 AM
Seb_PDR,
I highly recommend looking at the Product Brief for the 7-series defense grade first and then delve into the overview data sheet for more detail. The brief should contain a break down of the differences between XC and XQ and what sets the XQ apart. I'll list the main ones here for now:
• Full range extended temperature testing
• Mask set control
• Full compliance with MIL-PRF-38535 Pb content standards
• Longer-term availability • Anti-counterfeiting features
• Ruggedized & Leaded packaging option
• Available information assurance
• Available anti-tamper methodology
Tezz
11-14-2018 12:31 AM
Thank you for your answer.
I asked this question because I have found some radiation data on the XC7Z020 in scientific publications and I would like to know if they are applicable on the XQ7Z020.
Could you confirm this ? Are the mask layout, fabrication process, etc the same for both components ?
Thanks by advance
Seb_pdr,
Tezz
11-20-2018 11:31 PM - edited 11-20-2018 11:32 PM
Thank you Tezz for your answer.
It is very helpuful.
