sevenclock
Differential clock out to gtx refclk in via cleaner pll
i want to feed out a differential clock signal to a cleaner pll and the output of that pll is connected to the gtx refclk input.
Which primitives do i need to feed a diff. clk out.
Kintex7
Vivado 2015.1
gszakacs
Professor
Professor
If the clock you want to drive out is on a buffered clock net, then the best way is to instantiate an ODDR followed by an OBUFDS.  There should be examples of this if you search documentation for "clock forwarding."  You should also make sure that the LVDS output of the FPGA gives sufficient drive level to the jitter cleaner, and that the jitter cleaner provides sufficient drive for the GTX reference clock input.  Usually cap coupling is required in the GTX clock path, and depending on the drive style (LVPECL, CML... ) of the jitter cleaner you may need resistors to pull down and/or terminate the signal.
-- Gabor
aher
With "gtx refclk input" do you mean GTGREFCLK input which will be selected when CPLLREFCLKSEL[2:0] = 111? OR GTREFCLK[0/1]?
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
sevenclock
I do not exactly know what you mean but the ref clk will be connected to the IBUFDS_GTE2  buffer and its output to the gt_common.GTREFCLK0_IN input.
pulim
HI ,
It is not recommended to use fabric clock for GT refclk input. You should be driving it from the board.
aher
you can directly take the differential clock in and connect it to the ports of IBUFDS_GTE2. as it is having differential inputs and this is recommended practice as Manusha said.
for more information on this primitive you can refer to below given UG page #33
http://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf
Shreyas
sevenclock
As i said i will feed out the clock to a cleaner pll.
The cleaner pll will attenuate the jitter and forward it to the transceiver.
FPGA_DIFF_CLK_OUT  ->  cleaner_pll  ->  FPGA_GTX_REFCLK_INPUT
gszakacs
Professor
Professor
-- Gabor
