Drive strength
What is the default drive strength for the Done pin in Spartan 6 devices?
Hi @mohd_suhel ,
Its 8mA.
For more information refer page 83 of UG380 (v2.11).
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @mohd_suhel ,
Its 8mA.
Deepak D N
Thanx although just now I also found the same in data sheet
