06-06-2018 12:45 PM
I am working on a design in Vivado 2018.1 where I want to use LVDS_25 IOSTANDARD on a pin pair that is placed in a 3.3V bank which should work according to AR 43989 if I set DIFF_TERM to false.
Below is the error in the implementation log file:
Running DRC as a precondition to command place_design INFO: [DRC 23-27] Running DRC with 2 threads ERROR: [DRC BIVC-1] Bank IO standard Vcc: Conflicting Vcc voltages in bank 13. For example, the following two ports in this bank have conflicting VCCOs: SCL_RX_HDMI_DP159 (LVCMOS33, requiring VCCO=3.300) and HS88_EDP_AUX_P (LVDS_25, requiring VCCO=2.500)
Here is the XDC definning the two pins that the error is complaining about:
set_property -dict {IOSTANDARD LVDS_25 PACKAGE_PIN N21 DRIVE 16 DIFF_TERM FALSE} [get_ports HS88_EDP_AUX_P]; set_property -dict {IOSTANDARD LVCMOS33 PACKAGE_PIN N26 DRIVE 16} [get_ports SCL_RX_HDMI_DP159];
I opened the synthesized design and verified that DIFF_TERM was correctly set to false:
get_property DIFF_TERM [get_ports HS88_EDP_AUX_P] 0
Any ideas what I am doing wrong here?
Tim
06-11-2018 10:25 AM - edited 06-11-2018 10:26 AM
@tim_severance From what I see on your test design, you are assigning LVDS_25 to an Output in a 3.3V Bank which is not allowed and hence the tool complains.
You can have LVCMOS33 (Input or Output) in a Bank and "only" have LVDS_25 as an input (IBUFDS not OBUFDS) in the same bank. The AR you referred to mentions the same. DIFF_TERM is applicable for inputs and not Outputs.
As a test, you can make HS88_EDP_AUX_P/N an input in your design, you will not see the DRC.
06-06-2018 01:29 PM
As an example I setup a very simple project in Vivado 2018.1 with the following files and got the same exact error:
Project setup with xc7k160tffg676-1:
dummy_top.v:
module dummy_top( output dummy1_N, output dummy1_P, input dummy2 ); OBUFDS OBUFDS_inst ( .O(dummy1_P), // 1-bit output: Diff_p output (connect directly to top-level port) .OB(dummy1_N), // 1-bit output: Diff_n output (connect directly to top-level port) .I(dummy2) // 1-bit input: Buffer input ); endmodule
constr.xdc:
set_property -dict {IOSTANDARD LVDS_25 PACKAGE_PIN N22 DIFF_TERM FALSE} [get_ports dummy1_N]; set_property -dict {IOSTANDARD LVDS_25 PACKAGE_PIN N21 DIFF_TERM FALSE} [get_ports dummy1_P]; set_property -dict {IOSTANDARD LVCMOS33 PACKAGE_PIN N26 DRIVE 16} [get_ports dummy2];
Errors when running implementation:
06-06-2018 02:03 PM
Another piece of information:
If I tell Vivado to ignore BIVC-1 DRC by adding the below to the constr.xdc file I get the following errors.
XDC addition:
set_property IS_ENABLED 0 [get_drc_checks BIVC-1];
Errors:
Phase 1.2 IO Placement/ Clock Placement/ Build Placer Device ERROR: [Place 30-372] Bank.13 has terminals with incompatible standards: Incompatible Pair of IO Standards: LVCMOS33 and LVDS_25 The following terminals correspond to these IO Standards: SioStd: LVCMOS33 VCCO = 3.3 Termination: 0 TermDir: In Bank: 13 Placed : Term: dummy2 SioStd: LVDS_25 VCCO = 2.5 Termination: 0 TermDir: Out Bank: 13 Placed LVDS : Term: dummy1_P Term: dummy1_N ERROR: [Place 30-374] IO placer failed to find a solution Below is the partial placement that can be analyzed to see if any constraint modifications will make the IO placement problem easier to solve. +-------------------------------------------------------------------------------------------------------------------------------------------------------------------------+ | IO Placement : Bank Stats | +----+-------+-------+------------------------------------------------------------------------+------------------------------------------+--------+--------+--------+-----+ | Id | Pins | Terms | Standards | IDelayCtrls | VREF | VCCO | VR | DCI | +----+-------+-------+------------------------------------------------------------------------+------------------------------------------+--------+--------+--------+-----+ | 0 | 0 | 0 | | | | | | | | 12 | 50 | 0 | | | | | | | | 13 | 50 | 3 | LVCMOS33(1) LVDS_25(2) | | | +2.50 | YES | | | 14 | 50 | 0 | | | | | | | | 15 | 50 | 0 | | | | | | | | 16 | 50 | 0 | | | | | | | | 32 | 50 | 0 | | | | | | | | 33 | 50 | 0 | | | | | | | | 34 | 50 | 0 | | | | | | | +----+-------+-------+------------------------------------------------------------------------+------------------------------------------+--------+--------+--------+-----+ | | 400 | 3 | | | | | | | +----+-------+-------+------------------------------------------------------------------------+------------------------------------------+--------+--------+--------+-----+ IO Placement: +--------+----------------------+-----------------+----------------------+----------------------+----------------------+ | BankId | Terminal | Standard | Site | Pin | Attributes | +--------+----------------------+-----------------+----------------------+----------------------+----------------------+ | 13 | dummy1_P | LVDS_25 | IOB_X0Y76 | N21 | | | | dummy1_N | LVDS_25 | IOB_X0Y75 | N22 | | | | dummy2 | LVCMOS33 | IOB_X0Y90 | N26 | | +--------+----------------------+-----------------+----------------------+----------------------+----------------------+ INFO: [Timing 38-35] Done setting XDC timing constraints. Phase 1.2 IO Placement/ Clock Placement/ Build Placer Device | Checksum: 121f09e51 Time (s): cpu = 00:00:01 ; elapsed = 00:00:01 . Memory (MB): peak = 1081.402 ; gain = 12.434 Phase 1 Placer Initialization | Checksum: 121f09e51 Time (s): cpu = 00:00:01 ; elapsed = 00:00:01 . Memory (MB): peak = 1081.402 ; gain = 12.434 ERROR: [Place 30-99] Placer failed with error: 'IO Clock Placer failed' Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure. Ending Placer Task | Checksum: 121f09e51 Time (s): cpu = 00:00:01 ; elapsed = 00:00:01 . Memory (MB): peak = 1081.402 ; gain = 12.434 36 Infos, 1 Warnings, 0 Critical Warnings and 4 Errors encountered. place_design failed ERROR: [Common 17-69] Command failed: Placer could not place all instances INFO: [Common 17-206] Exiting Vivado at Wed Jun 6 13:59:37 2018...
06-06-2018 04:50 PM
Hi @tim_severance. Can you try not setting DIFF_TERM to FALSE? FALSE is the default value.
One way to test this without re-running synthesis would be to run the following commands after the failure.
reset_property DIFF_TERM [get_ports HS88_EDP_AUX_P]
place_design
06-06-2018 06:27 PM
Hi @marcb,
I reran implementation with the constraint file below and got the same results.
#set_property DIFF_TERM FALSE [get_ports dummy1_N]; set_property IOSTANDARD LVDS_25 [get_ports dummy1_N]; set_property PACKAGE_PIN N22 [get_ports dummy1_N]; #set_property DIFF_TERM FALSE [get_ports dummy1_P]; set_property IOSTANDARD LVDS_25 [get_ports dummy1_P]; set_property PACKAGE_PIN N21 [get_ports dummy1_P]; set_property IOSTANDARD LVCMOS33 [get_ports dummy2]; set_property PACKAGE_PIN N26 [get_ports dummy2]; set_property DRIVE 16 [get_ports dummy2]; #set_property IS_ENABLED 0 [get_drc_checks {BIVC-1}]
As far as doing the reset and place_design wouldn't I have to have an implemented design opened to do that?
Tim
06-11-2018 09:24 AM
@marcb, Any updates on this? This should be possible according to AR43989. Is this a bug in Vivado 2018.1?
Tim
06-11-2018 10:27 AM
Oh thank you, that is the piece I was missing. So what I am trying to do is not possible then.
Tim
