Error: found '0' definitions of operator "+", cannot determine exact overloaded matching definition for "+"
I'm creating a 4 bit counter and I got Error message about,
" Error: found '0' definitions of operator "+", cannot determine exact overloaded matching definition for "+" ".
How to solving this error?
This error was correct when I used "use IEEE.std_logic_signed.all;" Library.
Thank for all.
Try using IEEE.numeric_std.all and making Q either signed or unsigned.  Math operations on std_logic_vectors should be avoided.
ghd.rohan@gmail.com,
Use type_casting. The + operator will work with unsigned types. Revert back to std_logic_vector later or as needed.
Q <= std_logic_vector(unsigned(Q) + 1);
FPGA enthusiast!
All PMs will be ignored
Thank for all.
