dhzhang
Example design for AC701 SFP
Please forgive me -- I am a FPGA newbie, have A LOT of questions. Here come the first 2:
1. I managed to re-build and load the example IBERT design for bank 213, but cannot seem
     to be able to change the bit rate from 6.25 G to 2.5 G.  I could re-config the GTP, the project
     could build, but when I load the new bit file, the link status still says 6.25 Gbps.  What am I
     missing?
2. What I really need is an example design to use the SFP (with GTP x0y0).  I need to use 8p/10p
    to test some communication.
Please help!
Thank you very much in advance,
(I use Vivado 2015.2)
austin
d,
What "link status"?
Austin Lesea
Principal Engineer
Xilinx San Jose
fpgaioc
Hi Austin,
Thank you very much for helping!
I was referring to the "Status" inside the "Serial I/O Links" panel on the bottom of Vivado.
Could you point me to an example GTP design for the SFP on AC701?  Sorry if it too simple,
I just cannot find anybody talking about it anywhere.
Best regards,
htsvn
hi,
have you tried to run the example design available at this link
--hs
fpgaioc
Hi HS,
Thank you very much for helping.
Yes, I could re-build and run the IBERT example project.  One confusion is that I tried
to change the rate from 6.25 to 2.5.  The IP was configured, the project could build.  But
when I load it, the "Serial I/O Links" still shows "6.250 Gbps".
And, which ports are the "RX PLL Status" and "TX PLL Status"?  When I remove the
loopback fiber, they still show "Locked".
Which output port showes that the RX CDR is locked?  Is it "RXCDRLOCK"?  I am looking
for an indicator to show that the RX is getting data from the fiber.  So when the fiber is
unplugged, it provides a warning.
Best regards,
balkris
https://forums.xilinx.com/t5/7-Series-FPGAs/Example-design-for-AC701-SFP/td-p/652571
http://www.xilinx.com/support/documentation/boards_and_kits/ac701/2014_3/xtp224-ac701-ibert-c-2014-3.pdf
Thanks and Regards
Balkrishan
venkata
I tried to change the rate from 6.25 to 2.5.
How did you do it? Is it from core generation GUI?
