Example using the XRFSoC Data Converter
I'm trying to get the loopback working on a ZCU111 with the  XBM500, I have two sma connected with P/N crossed however I don't seem to find an example to use Vitis with standalone to program and send receive from ADC to ADC on C.
I have it all build, but I can't find an example on how to leverage the standalone format and make an application to read/write the ADC/DAC units on the board, like how o initially setup and etc, there are some examples using a a closed app from some example, but no example on how I can use and access the devices on my own.
basically in the latest 2020.2  zcu111_MTSDesign_8x8 from rdf0476 what is the ADC Data Capture block and DAC Stimuylus Block? and how toa access them then?
pthakare
Hi @muscularbeaverwhoosh
Chapter 6 (Example Design) in IP product guide below  has covered this blocks
https://www.xilinx.com/support/documentation/ip_documentation/usp_rf_data_converter/v2_4/pg269-rf-data-converter.pdf
Do you want external loopback  DAC -> ADC or Internal loopback ADC -> DAC ?
The example applications code provided below works with example design
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/rfdc/examples
The example design is created using right click to IP -> Open example design
Reply if you have any queries, give kudos and accept as solution
Thanks, but the example has an RTL block reading and writing, through the AXI Stream. Regarding the 2020.2 MTS_8x8 examples, that is a more "high/intensive data volume", in that case, I assume the process goes through the AxiDMA, like in the AxiDMA examples. Am I correct until here? Took me a whole day to figure because there is no example in using the A53, to send receive data on standalone/baremetal.
I have a current Design where I have all AXIS  and MAXIS of the DataConveter connected into a few peripheral interconnect, and there are a few issues with the timing of that. I create a derivative design, using DMA in and A DMA out, however, I didn't add the DDR4, and the DMA is before a peripheral interconnect and after, I don't particularly like it, but solve the timing issue, since I can make it work, however after exporting it the XRFSoC drivers where not present when I created the platform, so I can't access the unit
To be clear in my intent: is to use all DAC and ADC, in parallel, control by the MPSoC directly or indirectly, Yes like in the example I can create a secondary block to interface with ARM, and use this block to feed the DAC and another to sample the ADC, and feed the ARM.
Currently, I'm trying to get the loopback working ASAP, so then I can refine it and add more modules, and figure it out the best RTL design to extract the most performance of it.
pthakare
The designs provided in package (like MTS ,NON-MTS , SSRIP) are to be used with ZCU111 Evaluation GUI.
The documentation around this is
https://www.xilinx.com/support/documentation/boards_and_kits/zcu111/2020_2/ug1287-zcu111-rfsoc-eval-tool.pdf
https://www.xilinx.com/support/documentation/user_guides/ug1309-rf-data-converter-interface.pdf
Now coming to your requirement ,
We do have some starter designs hosted under lounge and you need to request for access.
Are you in contact with FAE  (Form Avnet or Xilinx) who can assist on getting the access to lounge?
thanks, @pthakare, not an FAE, only direct support inside Xilinx (not sure if is not you) by email, with an open case.
How can I get those LOUNGE designs you mentioned?
pthakare
There is link to request the access.
Can you provide me the case (SR) number ?
SR# 10516141
pthakare
Thanks , i checked it and this one is owned by timing expert . I will try to share the link with him to send on SR email thread.
Got it, our discussion is more architectural here, I think are two parallel discussions.
