FM-S14 daughter board KC705
I'm using KC705 evaluation board and FM-S14 daughter board.
until now using 7 SeriesTransceiver Wizard IP core we can generate 10 gigabit signal on SFP+(on board SFP+) and SMA using external clock.
now we want use daughter board SFP+ to transmit 10 gigabit, but when we create a core that use this SFP+, nothing happened.
daughter board SFP+ mapped to quad 118 and SMA and on board SFP+ mapped to quad 117. in our project all three MGTuse same reference clk(quad 117 : SMA_MGT_REFCLK). now SMA and on board SFP+ work but FM-S14 doesn't work.
what should I do to solve this problem?
thanks in advance
Re: FM-S14 daughter board KC705
Finally I find the solution, this daughter board has sfp_tx_disable signal and I make it to be 1'b0, means enable.
also this problem doesn't has any relation to switch state at all.
Daughter generate output clock that we can use in our design and clock rate just can change with switch state.
thanks
Have you read the hardware setup for connectivity at http://www.xilinx.com/support/documentation/boards_and_kits/k7_conn/2013_3/ug929_K7_Connectivity_GSG.pdf
For example, have you ensured that switches P1 and P2 on the FM-S14 FMC card are in the ON position?
I read it before and think my configuration is similar to ug929.
P1 to P2 is in On position now but nothing changed!
is there any jumper or something else exist related to this daughter board?
thanks
I am using VC707 and FMC module
http://www.hitechglobal.com/FMCModules/FMC_4SFP+_Module.htm
I am facing the problem as in the link below:
http://forums.xilinx.com/t5/New-Users-Forum/VC707-USER-SMA-CLK-P-N/td-p/649932/page/2
What could I do to slove the above problem?
